i tried to do some queries on joiend table fields ...
i've got/found some answers concerning version 1.8 - which result in "use select + export to create a combined dataset"so i just did some tests with Layer / query in qgis 2.2 valmiera and 2.3-master(build from 2014-05-02)) and ended up with the same problems:
while
to select data by expression and export geometry and "added" additional data really undermines this concept by duplicating data !!!
so: does anybody have any idea how to deal with that problem ?
best regards robert
while
- "layer properties / style / column expression" tool is working finebased on "external" fields - even if i build complex expressions
 - and "table - select faetures by expressionn" doesn't seem to have any problems with where-clauses
- no problems with expressions unsing fields from the layer's attribute table
but - as soon as i address "external" fields - but - as soon as i address "external" fields
- the test feature returns an error:a simple query like "zsp_experimente_xls_WFL01_AREA" >= 1.52"(where 1.52 is valid value out of the sample-list) returns
"OGR 3 error 1: type mismatch or improper type of arguments to >= operator"
but "zsp_experimente_xls_WOHNFL01_AREA" LIKE "%" returns all records when testing the query ("the where clause teturned 1364 rows") - the confusing thing about that:
the the sample tool privides correct results ! ! !
((which means to me that the select part of the statement works fine))
best regards robert
