Please help me to fit the map extent into de qgscomposermap size.
printable_layers = QgsMapLayerRegistry.instance().mapLayers().values() printable_layers_ids = [] bigger_printable_layer = None for layer in printable_layers: printable_layers_ids.append(layer.id()) if type(bigger_printable_layer) != type(None): if layer.extent().width() + layer.extent().height() > bigger_printable_layer.extent().width() + bigger_printable_layer.extent().height(): bigger_printable_layer = layer else: bigger_printable_layer = layer printable_layers_ids.reverse() template_document = QtXml.QDomDocument() template_document.setContent(QtCore.QFile(Printer.printing_template_file_path), False) map_renderer = QgsMapRenderer() map_renderer.setLayerSet(printable_layers_ids) rect = QgsRectangle(map_renderer.fullExtent()) rect.scale(1.1) map_renderer.setExtent(rect) map_renderer.setOutputSize(QSize(800, 600), 300) composition = QgsComposition(map_renderer) composition.loadFromTemplate(template_document) composer_map = QgsComposerMap(composition, 0, 0, composition.paperWidth(), composition.paperHeight()) composer_map.setNewExtent(rect) composer_map.updateItem() composition.addComposerMap(composer_map) # add created map to composition layers list composition.refreshZList() # not working # composition.moveItemToBottom(composer_map) # must do that instead composition.setAllUnselected() composition.setSelectedItem(composer_map) composition.moveSelectedItemsToBottom() # must refresh composition.refreshZList() composition.refreshItems() composition.exportAsPDF(printed_file_path + ".pdf")rendering
