Qgis Text/Annotation as layer
Is there a way to add text/annotation to my map in QGIS as a layer?I have a map of vegetation types an point data the text (field names/flurnamne) should be between these two layers. It there must not be a background or box around it and should not cover the points. It would be ideal if I could arrange the text on a path or line as the shortest name must stand for the largest area.
Is there a way to add annotation just a text, no box, background or point?
At the moment I just added text in print composer and set transparency, but results are not very satisfying
EDIT: The text should be under the points. I have a map with the vegetation types and the point data and want to add the fieldnames/flurnamen of certain area. It would ideal if spacing etc. could be adjusted so that the text covers the whole area, e.g. name_1 in on the line.
