A basic QGIS 2.2.0-Valmiera, Select By Expression - Field Calculator question.
Introduction
I am a geologist searching through a geological database (see attached figure). I have a shape file and associated attribute file of which I would like to select certain records within a field to make as new shape file layer.
Task/method
I wish to search the 'GEOLHIST' and select Permian lithologies using the field calculator. Subsequently I shall Save Selection As. I have tried using the following script unsuccessfully.
"GEOLHIST" IS 'Early Carboniferous to Early Permian' OR 'Early Permian' OR 'Early Permian to Late Carboniferous' OR 'Early Permian to Late Permian' OR 'Late Carboniferous to Early Permian' OR 'Late Carboniferous to Permian' OR 'Late Permian' OR 'Late Permian to Permian' 'Permian' OR 'Permian to Early Permian'Question
What script can I use to select the above records?
Discussion
'GEOLHIST' IS 'Permian'This script works. I have looked at the other OPERATORS (AND OR IS LIKE) and CONDITIONALS and have not figured out how to achieve my task.
Yours sincerely,Tom
EDIT
Hello,
I am grateful for the response, thank you Martin and Nathan.
Nathan provided a working script, see attached figure.
I was not aware of the SQL operator in or the method of bracketing. This technique will be most helpful in the future.
"GEOLHIST" IN ( 'Carboniferous to Early Permian' , 'Early Permian' , 'Early Permian to Late Carboniferous' , 'Early Permian to Late Permian' , 'Late Carboniferous to Early Permian' , 'Permian' , 'Permian to Early Permian')
Introduction
Task/method
Discussion
Yours sincerely,Tom
EDIT
Hello,
