I have a problem with labels in QGIS. I'm using a background svg for some labels (street numbers). In QGIS, it's all ok but when I use the composer there is a bug (I suppose), because I see some strange artifacts.
see http://i.stack.imgur.com/Irqkn.jpg
If I disable the layer with the street numbers, or if I remove the svg background, the artifacts disappear. The problem is reproducible only with svg, if I use the rectancle or another option, I don't see any problems. The artifacts can be seen in the composer preview too.
Can someone confirm this problem?
Tested with QGIS 2.6.1 and 2.8.1 Nightly
