I have a shapefile with points, and a shapefile with polygons. I want to sum the attribute value of all points that are within a certain polygon, and I'd like to do this for each polygon in my dataset. QGIS' Join Attributes by Location tool is helping me to achieve this, and is working perfectly when using the tool via the Processing Toolbox. However, I would like to include the tool in an automated script. I tried many different arguments, but my code is (still) not working, and results in a dataset where the new polygon attribute has NULL values.
I'm using the following code, which should be exactly the same as the tool is running when I'm accessing it from the Processing Toolbox (I even tried copying and running the exact same code from the History & Log window):
sum = processing.runalg("qgis:joinattributesbylocation","polygonlayer.shp","pointlayer.shp","['contains']",1,"sum",1,None) I'm using QGIS 2.8.2 Wien. It's my first question here, so I hope I've been clear enough.
Thanks in advance!
Thanks in advance!
