QGIS import osm data via OSM-plugin and sqlite does not only import selected tags
I have the following problem: I want to use the OSM plugin to import data from a sqlite database that contains OSM data. In the 'Export OSM topolgy to spatialite' dialog I choose the database file and the polygon geometry. Then I click the 'Exported tags' button. This shows me the list of tags together with the count of features. In my case, I select admin_level, which has 267 features. Now I press ok. After the export, I would expect that only 267 features are inserted in the added layer. But when I check the feature count of the new layer it has about 52000 tags, which is pretty much every polygon. When I had a look at the attribute table the admin_level field has the value NULL for every feature.
So, I'm not sure what I'm missing here. Any help or advice is appreciated.
Torsten.
