I'm exporting a map to PDF in the print composer.See the map in the print composer
As you can see, the top map is different from the bottom; the top has 10 tracts shaded in, the bottom has 6.
Now see how it is when I export it to PDF
Both the top and the bottom have the same tracts filled in!
Is it an export problem? Is it a layer problem? Is it another problem?
