QGIS does not read ESRI Geodatabase correctly
I have a geodatabase from the EPA that does not seem to me reading correctly with Quantum GIS. QGIS Version 1.8.0 (Lisboa) and GDAL/OGR 1.9.2
When I open the attribute table the first two columns have the same data. The first column is CERCLA_ID and the second is SITE_NAME. both columns have the SITE_NAME value. As far as I can tell all else is is correct.
I opened various files in the .gdb folder using a hex editor and in the a00000004.gdbtable file the data is stored in an XML format internally and the correct CERCLA_ID value is indeed being stored along with the SITE_NAME.
Is there something wrong with the file or something wrong with the program?
I also heard back from my EPA contact. He says they are using "attribute domains" on their end.
