Qgis - Couldn't load plugin 'processing' - name 'QsciLexerCustom' is not defined - Ma
UPDATED
I receive the following error when I start Qgis:
Couldn't load plugin 'processing' from ['/usr/share/qgis/python', '/home/v/.qgis2/python', '/home/v/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python27.zip', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/lib/python2.7/site-packages', '/usr/lib/python2.7/site-packages/gst-0.10', '/usr/lib/python2.7/site-packages/gtk-2.0', '/usr/lib/python2.7/site-packages/wx-3.0-gtk2', '/home/v/.qgis2/python/plugins/mmqgis/forms', '/usr/share/qgis/python/plugins/fTools/tools']Traceback (most recent call last):File "/usr/share/qgis/python/qgis/utils.py", line 182, in loadPlugin__import__(packageName)File "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/__init__.py", line 29, in from processing.tools.general import *File "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/tools/general.py", line 29, in from processing.core.Processing import ProcessingFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/core/Processing.py", line 55, in from processing.r.RAlgorithmProvider import RAlgorithmProviderFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/r/RAlgorithmProvider.py", line 34, in from processing.gui.EditScriptAction import EditScriptActionFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/gui/EditScriptAction.py", line 29, in from processing.gui.ScriptEditorDialog import ScriptEditorDialogFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/gui/ScriptEditorDialog.py", line 42, in from processing.gui.ScriptEdit import ScriptEditFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/gui/ScriptEdit.py", line 36, in from processing.gui.LexerR import LexerRFile "/usr/share/qgis/python/qgis/utils.py", line 453, in _importmod = _builtin_import(name, globals, locals, fromlist, level)File "/usr/share/qgis/python/plugins/processing/gui/LexerR.py", line 34, in class LexerR(QsciLexerCustom):NameError: name 'QsciLexerCustom' is not definedPython version:2.7.6 (default, Feb 15 2014, 23:06:13) [GCC 4.8.2 20140206 (prerelease)]QGIS version: 2.3.0-Master Master, ccde1d4Python path: ['/usr/share/qgis/python', u'/home/v/.qgis2/python', u'/home/v/.qgis2/python/plugins', '/usr/share/qgis/python/plugins', '/usr/lib/python27.zip', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/lib/python2.7/site-packages', '/usr/lib/python2.7/site-packages/gst-0.10', '/usr/lib/python2.7/site-packages/gtk-2.0', '/usr/lib/python2.7/site-packages/wx-3.0-gtk2', '/home/v/.qgis2/python/plugins/mmqgis/forms', '/usr/share/qgis/python/plugins/fTools/tools']First, I don't know anything about python, so forgive me if the information I provide is a bit random and don't hesitate to ask more.I also do not know how to define something in python but at first sight and from my limited understanding, it seemed pretty well defined:
Indeed, in /usr/share/qgis/python/plugins/processing/gui/ the LexerR.py file specifies:
from PyQt4.Qsci import *
In /usr/share/sip/PyQt4/Qsci/ there is a qscilexercustom.sip file specifying:
'#include'
and the file qscilexercustom.h exists in the /usr/include/qt4/Qsci/ folder.
I had Qgis 2.0 before, with the same issue, and installed this development version with the faint hope that it might solve my problem.
Would you have any idea how to solve this issue?
Thanks!
UPDATE
Thanks for the tip!
Here is what I get when I try to import PyQt4.Qsci:RuntimeError: the sip module implements API v11.0 but the PyQt4.Qsci module requires API v10.1
So I guess now I'll try to downgrade sip, though I had to install sipdev to compile Qgis.I'll let you know what comes up.
Thanks,
UPDATE 2
Downgrading sip wasn't such a good idea since it is required by PyQt4. Here's is what I get when I try to launch qgis:
Couldn't load PyQt4.Python support will be disabled.Traceback (most recent call last):File "", line 1, in RuntimeError: the sip module implements API v10.0 to v10.1 but the PyQt4.QtCore module requires API v11.0Same when I try to import PyQt4.Qsci from python:
RuntimeError: the sip module implements API v10.0 to v10.1 but the PyQt4.QtCore module requires API v11.0Note that python-qscintilla, python-qscintilla-common, python2-qscintilla and qscintilla are all installed in version 2.8-1.
Any ideas? Thanks!
