Error occurs under Windows in QGIS 2.8.3 and 2.10.1Answers to similar questions eg 57418 have not helped.
The shape file in question was created as follows:
Vector/GPS/GPS tools/Load GPX file (Routes)
Layer / save as ESRI shape file [....\epsg4326\routes.shp
The failing sequence is:
Start a new map/add vector layer [routes.shp]
Open attribute table
Add new column AREA [decimal real width=17 precision=8]
Manually edit both AREA values to verify format.
Select all entries [2 entries]Field calculator / existing /AREA / geometry / $areaAlways get NULL
I have tried countless combinations of width and precision for AREA. I have installed/reinstalled different releases to no avail.
What's up Doc?
PS: Beginning to smell a rat in the direction of either the GPS tool or the shape file. Starting with the shape file, how may I independently verify it!
What's up Doc?
