QGIS 2.8 Error 1: Can't Load reauested DLL
Greetings,I am attempting to run the Topographic wetness index tool in QGIS with Windows 7. When I run the tool, I get this error:
SAGA execution console output
C:\PROGRA~1\QGISWI~1\bin>set SAGA=C:/PROGRA~1/QGISWI~1/apps\saga
C:\PROGRA~1\QGISWI~1\bin>set SAGA_MLB=C:/PROGRA~1/QGISWI~1/apps\saga\modules
C:\PROGRA~1\QGISWI~1\bin>PATH=PATH;C:/PROGRA~1/QGISWI~1/apps\saga;C:/PROGRA~1/QGISWI~1/apps\saga\modules
C:\PROGRA~1\QGISWI~1\bin>saga_cmd io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Users\tuf81784\AppData\Local\Temp\processing\74f99a7b632243618615b00cf4096fa0\slopeEXT.sgrd" -FILES "C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/slope_EXT.tif"ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISWI~1\apps\saga\dll\gdal_MrSID.dll127: The specified procedure could not be found.
# ## ##### #library path: C:\PROGRA~1\QGISWI~1\apps\saga\modules\io_gdal.dlllibrary name: Import/Export - GDAL/OGRtool name : GDAL: Import Rasterauthor : O.Conrad (c) 2007 (A.Ringeler)
Parameters
Grids: No objectsFiles: "C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/slope_EXT.tif"Transformation: yesInterpolation: Nearest Neighbor
loading: C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/slope_EXT.tif
Driver: GTiff
Bands: 1
Rows: 1071
Columns: 689
Transformation:
x' = 487383.576000 + x * 0.050000 + y * 0.000000
y' = 4425593.490000 + x * 0.000000 + y * -0.050000
warning: top-to-bottom and left-to-right cell sizes differ.using cellsize: 0.050000
loading band [1/1]
C:\PROGRA~1\QGISWI~1\bin>saga_cmd io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Users\tuf81784\AppData\Local\Temp\processing\f11d4e645ce3499e965d0b6a50ccfd5b\catchEXT.sgrd" -FILES "C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/catch_EXT.tif"ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISWI~1\apps\saga\dll\gdal_MrSID.dll127: The specified procedure could not be found.
Parameters
Grids: No objectsFiles: "C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/catch_EXT.tif"Transformation: yesInterpolation: Nearest Neighbor
loading: C:/Users/tuf81784/Box Sync/BoxSharePaul/PAUL_Research/GIS_Data/Berks GIS/Wetness Index Calculation/2015_07_07/catch_EXT.tif
Driver: GTiff
Bands: 1
Rows: 1071
Columns: 689
Transformation:
loading band [1/1]
C:\PROGRA~1\QGISWI~1\bin>saga_cmd ta_hydrology "Topographic Wetness Index (TWI)" -SLOPE "C:\Users\tuf81784\AppData\Local\Temp\processing\74f99a7b632243618615b00cf4096fa0\slopeEXT.sgrd" -AREA "C:\Users\tuf81784\AppData\Local\Temp\processing\f11d4e645ce3499e965d0b6a50ccfd5b\catchEXT.sgrd" -CONV 0 -METHOD 0 -TWI "C:\Users\tuf81784\AppData\Local\Temp\processing\c2d65c8d54624277b66cfe15493f6f64\TWI.tif.sgrd"ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISWI~1\apps\saga\dll\gdal_MrSID.dll127: The specified procedure could not be found.
# ## ##### #library path: C:\PROGRA~1\QGISWI~1\apps\saga\modules\ta_hydrology.dlllibrary name: Terrain Analysis - Hydrologytool name : Topographic Wetness Index (TWI)author : O.Conrad (c) 2003
Load grid: C:\Users\tuf81784\AppData\Local\Temp\processing\74f99a7b632243618615b00cf4096fa0\slopeEXT.sgrd...
Load grid: C:\Users\tuf81784\AppData\Local\Temp\processing\f11d4e645ce3499e965d0b6a50ccfd5b\catchEXT.sgrd...
Usage: saga_cmd ta_hydrology 20 -SLOPE -AREA [-TRANS ] [-TWI ] [-CONV ] [-METHOD ]-SLOPE: SlopeGrid (input)-AREA: Catchment AreaGrid (input)-TRANS: TransmissivityGrid (optional input)-TWI: Topographic Wetness IndexGrid (output)-CONV: Area ConversionChoiceAvailable Choices:[0] no conversion (areas already given as specific catchment area)[1] 1 / cell size (pseudo specific catchment area)Default: 0-METHOD: Method (TWI)ChoiceAvailable Choices:[0] Standard[1] TOPMODELDefault: 0Error: Catchment AreaError: executing tool [Topographic Wetness Index (TWI)]
C:\PROGRA~1\QGISWI~1\bin>saga_cmd io_gdal 1 -GRIDS "C:\Users\tuf81784\AppData\Local\Temp\processing\c2d65c8d54624277b66cfe15493f6f64\TWI.tif.sgrd" -FORMAT 4 -TYPE 0 -FILE "C:\Users\tuf81784\AppData\Local\Temp\processing\c2d65c8d54624277b66cfe15493f6f64\TWI.tif"ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISWI~1\apps\saga\dll\gdal_MrSID.dll127: The specified procedure could not be found.
# ## ##### #library path: C:\PROGRA~1\QGISWI~1\apps\saga\modules\io_gdal.dlllibrary name: Import/Export - GDAL/OGRtool name : GDAL: Export Rasterauthor : O.Conrad (c) 2007
Load grid: C:\Users\tuf81784\AppData\Local\Temp\processing\c2d65c8d54624277b66cfe15493f6f64\TWI.tif.sgrd...failedGDAL: Export Raster: could not initialize data objectsError: Grid file could not be opened.Error: executing tool [GDAL: Export Raster]
C:\PROGRA~1\QGISWI~1\bin>exit
When I navigate to C:\PROGRA~1\QGISWI~1\apps\saga\dll ... the gdal_MrSID.dll is there. Any idea on what the issue is? Thanks!
