Using: Mac OSX 10.9.4 QGIS 2.6.1
I had previously installed QGIS and had everything running fine. My home directory was /Users/rowanbado, but for another application I had to add an intermediate directory such that my home directory is now stored in /Users/bado/rowan. Now when I open QGIS I get the following error:
Couldn't load plugin processing due an error when calling its initGui() methodTraceback (most recent call last): File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 217, in startPluginplugins[packageName].initGui() File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/ProcessingPlugin.py", line 54, in initGuiProcessing.initialize() File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 145, in initializeProcessing.modeler.initializeSettings() File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/modeler/ModelerAlgorithmProvider.py", line 55, in initializeSettingsModelerUtils.modelsFolder())) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/modeler/ModelerUtils.py", line 46, in modelsFoldermkdir(folder) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/system.py", line 127, in mkdirmkdir(head) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/system.py", line 127, in mkdirmkdir(head) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/system.py", line 127, in mkdirmkdir(head) File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/tools/system.py", line 129, in mkdir os.mkdir(newdir)OSError: [Errno 13] Permission denied: '/Users/rowanbado'Which is particularly confusing because that directory no longer exists. I have tried the following workarounds:
-Uninstall and reinstall QGIS (as well as all frameworks, cairo,gdal,etc, and delete ~/.qgis2 folder). Didn't do anything.
-Comment out the line in 'ModelerUtils' (Line 46) which appears to be the source of error. I no longer receive an error message from 'ModelerUtils.py' (so I assume the module is running fine) but instead receive the same message as above except with SystemUtils.py, which I assume is the next module to be initialized. Clearly the issue is with the system.py module.
-Create a symbolic link in /Users/bado/rowan to /Users/rowanbado. Now everything works fine and I have no problems, but this is sort of a 'dumb' work around in that it treats the symptom and no the problem.
It seems that the Processing toolbox has stored a line with my old home directory path in some internal file, and now fails upon initialize and therefore cannot change this line as I assume it should. When I start up the (now working with a symbolic link) toolbox, then remove the symbolic link, I am right back to the same error.
Any developers out there have some idea what's going on and how I can address this? Seems to be a trivial issue to someone who understands the system very well.
Thanks in advance, Rowan.
