I have merged two polygon shape files(Vector). After merge I am facing problem at boundaries..
So I thought of changing Polygon -> lines(manually deleting one of the line at boundary) ->Finally change to Polygon.
The problem is I am not able select line between two nodes to delete, the entire polygon is getting selected when i try to select. Is there any better approach to do this, can I merge the lines please suggest.
