i am making a map that includes all kinds of vector layers; the map looks perfect in QGIS 2.12 Lyon as well as in map composer.None of the layers have scale-dipendent visibility; i have the following issues when exporting as image (regardless the output format):- A4 format: if i set the resolution to 200 dpi i get an image with all the layers displayed; if i set the resolution to 250dpi i don't get some vector layers in the output image (such as 25 meters contour lines and some land coverage); when i save with 300 dpi resolution i only get a basic map excluding polygons and all the contour lines.- A3 format and more: similar as above, but already at 200dpi i only get few layers printed in the output raster file.
The same project printed in QGIS 2.8 doesn't have the same issues and all the vector layers are exported properly.
