Qgis 2.10.1 Grass processing algorithms not working
I just did a fresh install of Qgis 2.10.1 from the qgis repos (ubuntu 14.04). I also have gras70 installed (through ubuntugis-unstable).
I can see the GRASS7 commands in the preocessing toolbox panel, but when I try to use them I got the Missing dependency. This algorithm cannot be run :-( message.
In the plugins log I noticed that Qgis could not load libgrassplugin6.so, but I'm guessing thats not the issue since I'm trying to run grass7 algorithms.
Also, on the processing log I got this output when trying to run a grass 7 command:
GRASS GIS 7 execution commands g.proj -c proj4="+proj=utm +zone=30 +ellps=intl +towgs84=-87,-98,-121,0,0,0,0 +units=m +no_defs" v.in.ogr min_area=0.0001 snap=-1 input="/usr/share/qgis/python/plugins/processing/tests/data" layer=points output=tmp1444494282425 --overwrite -o g.region -a n=4458983.8488 s=4458921.97814 e=270855.745301 w=270778.60198 res=100 v.voronoi input=tmp1444494282425 output=output22e863becb734ae4a06720411090abf0 --overwrite v.out.ogr -s -e input=output22e863becb734ae4a06720411090abf0 type=auto output="/tmp/processing/b5eb2443ef0840239dc22209a29a71db" format=ESRI_Shapefile olayer=outputBut when I try to run a grass command (without version, I think that means grass 6, doesn't it?), I got no output on the log. I think that must mean something.
Any help is appreciated.
