I am developing a Python toolbox, and came across a peculiar behavior: The tool objects does not remember any instance variables between function calls. Consider this code:
import arcpyclass Toolbox(object): def __init__(self): self.label = "Test" self.alias = "Test" self.tools = [Tool]class Tool(object): def __init__(self): self.label = "Test tool" self.x = "INIT" def getParameterInfo(self): param0 = arcpy.Parameter( displayName = "Parameter", name = "parameter", datatype = "String", parameterType = "Required", direction = "Input") return [param0] def updateParameters(self, parameters): self.x = "UPDATE PARAMETERS" def updateMessages(self, parameters): parameters[0].setWarningMessage(self.x) self.x = "UPDATE MESSAGES" def execute(self, parameters, messages): arcpy.AddMessage(self.x)The way I would expect this code to behave is this:
Is my conclusion correct? If so, why does ArcMap behave that way? From an OOP perspective it seems very strange.
This behavior causes big problems for me. The first parameter of the tool I am developing is a text file. When the user has picked one I want to populate the other parameters with different default values depending on the content of the file. Since the file could be rather large I do not want to have to parse it every time any parameter changes, but now it seems like I have to since there is no way to know if the parameter has changed or not.
- First __init__ is called, and x is set to "INIT".
- Then updateParameters is called, and x is changed to "UPDATE PARAMETERS".
- Then updateMessages is called. It displays a warning with the text "UPDATE PARAMETERS" and then change x to "UPDATE MESSAGES".
- Finally, when the tool is executed it outputs "UPDATE MESSAGES".
