Does anyone know where I can get a python script that can do a batch import of CAD files into a Geodatabase.
I have one I wrote here, but it is only able to import one CAD file at a time. It imports the CAD files and split it into feature classes and stores it in the geodatabase via the feature dataset.It works perfectly well but I need to loop the script to search through a given folder for all the cardfiles in it and import them under different feature datasets and put all the datasets into one geodatabase.
# Name: CadtoGeodatabase.py# Description: Create a feature dataset# Author: Irene# Import system modulesimport arcpyfrom arcpy import env# Set workspaceenv.workspace = "C:/data1"# Set local variablesinput_cad_dataset = C:\Users\iegbulefu\Documents\info\91036c01.dwg" output_gdb_path = "c:/data/cadfile.gdb"output_dataset_name = "cadresults"reference_scale = "1500"spatial_reference = "Nad_1983_10TM"# Create a FileGDB for the fdsarcpy.CreateFileGDB_management("C:/data1", "cadfile.gdb")# Execute CreateFeaturedataset arcpy.CreateFileGDB_management("C:/data", "cadfile.gdb")arcpy.CADToGeodatabase_conversion(input_cad_dataset, output_gdb_path, output_dataset_name, reference_scale)
