Python Script to convert a mass of KMLs to a single fGDB
I have a mass of KML files, approx 350+ that I need in a single fGDB. I lifted a string of code from ESRI help to attempt to do this - I got it working to the point of creating all the individual gGDBs (one per KML) but its failing with an invalid character in a variable somewhere. Below is the code, and then the error that it throws out. I've added some print commands to show whats in the variables right before it fails. Help? Also, this is my first time trying to use python for actual work, so I apologize in advance for n00bish mistakes.
# Name: BatchKML_to_GDB.py# Description: Converts a directory of KMLs and copies the output into a single fGDB.# A 2 step process: first convert the KML files, and then copy the featureclases# Import system modelsimport arcpy, os# Set workspace (where all the KMLs are) arcpy.env.workspace="C:\\Users\\mperez\\Desktop\\IT-Paths"# Set local variables and location for the consolidated file geodatabaseoutLocation = "V:\\2155\\active\\215510456\\GDB"MasterGDB = r'AllKMLLayers.gdb'MasterGDBLocation = os.path.join(outLocation, MasterGDB)# Create the master FileGeodatabase arcpy.CreateFileGDB_management(outLocation, MasterGDB)# Convert all KMZ and KML files found in the current workspace for kmz in arcpy.ListFiles('*.KM*'): print "CONVERTING: " + os.path.join(arcpy.env.workspace,kmz) arcpy.KMLToLayer_conversion(kmz, outLocation)# Change the workspace to fGDB locationarcpy.env.workspace = outLocation# Loop through all the FileGeodatabases within the workspacewks = arcpy.ListWorkspaces('*', 'FileGDB')# Skip the Master GDBwks.remove(MasterGDBLocation)for fgdb in wks: # Change the workspace to the current FileGeodatabase arcpy.env.workspace = fgdb # For every Featureclass inside, copy it to the Master and use the name from the original fGDB featureClasses = arcpy.ListFeatureClasses('*', '', 'Placemarks') for fc in featureClasses: print r"COPYING: " + fc + r" FROM: " + fgdb fcCopy = fgdb + os.sep + 'Placemarks' + os.sep + fc print r"fcCopy = " + fcCopy print r"MasterGDBLocation = " + MasterGDBLocation print r"fgdb = " + fgdb arcpy.FeatureClassToFeatureClass_conversion(fcCopy, MasterGDBLocation, fgdb[fgdb.rfind(os.sep)+1:-4])# Clean updel kmz, wks, fc, featureClasses, fgdbOutput from shell showing error:
COPYING: Points FROM: V:\2155\active\215510456\GDB\canal-move-2-golden-gate-blvd.gdbfcCopy = V:\2155\active\215510456\GDB\canal-move-2-golden-gate-blvd.gdb\Placemarks\PointsMasterGDBLocation = V:\2155\active\215510456\GDB\AllKMLLayers.gdbfgdb = V:\2155\active\215510456\GDB\canal-move-2-golden-gate-blvd.gdbTraceback (most recent call last): File "C:\Users\mperez\Desktop\batch_kml_to_gdb.py", line 46, in arcpy.FeatureClassToFeatureClass_conversion(fcCopy, MasterGDBLocation, fgdb[fgdb.rfind(os.sep)+1:-4]) File "C:\Program Files (x86)\ArcGIS\Desktop10.1\arcpy\arcpy\conversion.py", line 1547, in FeatureClassToFeatureClass raise eExecuteError: ERROR 000354: The name contains invalid charactersFailed to execute (FeatureClassToFeatureClass).
