I want to transform some vectors to rasters in my folder but I have difficulties setting the output folder. The following code only allows me to output to the original database. I hope to output all results to the same folder instead of in their original database. Thanks for any help!
import arcpy import os workspace = "D:\Jiawei default download" feature_classes = [] walk = arcpy.da.Walk(workspace, datatype="FeatureClass", type="Polygon") for dirpath, dirnames, filenames in walk: if "Subbasin" in filenames: filenames.remove('Subbasin') for filename in filenames: feature_classes.append(os.path.join(dirpath, filename)) print feature_classes for item in feature_classes[98:]: inFeatures = item valField = "wtdepaprjunmin" outRaster = item+"_r" print "processing "+item # Execute PolygonToRaster arcpy.PolygonToRaster_conversion(inFeatures, valField, outRaster)
