PYQGIS Refresh map composer
I have the same problem as this How to set up QGIS print composer options from the python console?
I have a composer template called "Template", I can open it with the python console but not edit the map content.
I'm very new to python so its likley to be something simple Ive overlooked. The ultimate aim is to loop through locations (from a shapefile) and create a map for each one with unique labels. I realise people have done similar things before, but none of my attempts have got them to work so I'm starting from scratch.
I'm using QGIS 2.8 on Windows 7.
Thanks in advance
from qgis.core import *from qgis.gui import *from qgis.utils import *from PyQt4.QtCore import *from PyQt4.QtGui import *from PyQt4.QtXml import *import tempfileimport os#test i=1cLayer = iface.mapCanvas().currentLayer()expr = QgsExpression( "\"ID\"=i" )it = cLayer.getFeatures( QgsFeatureRequest( expr ) )ids = [i.id() for i in it]cLayer.setSelectedFeatures( ids )canvas = qgis.utils.iface.mapCanvas()canvas.zoomToSelected()myFile = os.path.join('Z:\Output', 'Template.qpt')myTemplateFile = file(myFile, 'rt')myTemplateContent = myTemplateFile.read()myTemplateFile.close()myDocument = QDomDocument()myDocument.setContent(myTemplateContent, False)(True, u'', 0, 0)newcomp = iface.createNewComposer()newcomp.composition().loadFromTemplate(myDocument)Truecomposition = QgsComposition(canvas.mapSettings())map_item = composition.getComposerItemById('map')map_item.setMapCanvas(canvas)**Traceback (most recent call last):File "", line 1, in AttributeError: 'NoneType' object has no attribute 'setMapCanvas'map_item.zoomToExtent(canvas.extent())Traceback (most recent call last):File "", line 1, in AttributeError: 'NoneType' object has no attribute 'zoomToExtent'***
