PyQgis - Loading layers from postgres using SELECT statement
I am trying to load a postgres table (columns extracted using a select statement) from the python console in QGis:
The following works fine and the layer loads as expected:
uri = QgsDataSourceURI()uri.setConnection("*****","***","****","****","*****")uri.setDataSource("","mytable","geom","","id")vlayer = QgsVectorLayer(uri.uri(),"LayerName","postgres")QgsMapLayerRegistry.instance().addMapLayer(vlayer)if not vlayer.isValid(): print "layer failed to load"However, if I swap out the table name for an SQL select statement:
sql = "(select id from mytable)"uri.setDataSource("",sql,"geom","","id")vlayer = QgsVectorLayer(uri.uri(),"LayerName","postgres")QgsMapLayerRegistry.instance().addMapLayer(vlayer)if not vlayer.isValid(): print "layer failed to load"Then the layer fails to load.
Also, if I use a very long SQL statement to try to select more columns, I get a message in the terminal window along the lines of:
NOTICE: identifier "(lonq sql text here)" will be truncated to"​
Am I missing something? I am using QGis 2.4.
