PyQGIS: How to get the list of valid layers in TOC?
To get the list of TOC layer names I used the approach suggested here:
for layer in QgsMapLayerRegistry.instance().mapLayers().values(): print layer.name()But this method is not reliable due to it is able to catch "phantom" layers that are created when the preview option in DB Manager plugin is used (see this ticket) and were never added to TOC by user. Here is what happens:
>>>def laylist():>>> l=[]>>> for layer in QgsMapLayerRegistry.instance().mapLayers().values():>>> item = layer.name()>>> l.append(item)>>> print l# There is only one layer 'buf' (a shp-file) in QGIS TOC. Check the TOC>>>laylist()[u'buf']# Now open DM Manager, connect to the PostGIS DB and preview one of the spatially enabled tables ('park_kvartal3_utm') without adding them to TOC# Check TOC again:>>>laylist()[u'park_kvartal3_utm', u'buf']# Now in DB Manager select another spatial table ('itog_region_utm') and preview it without adding it to TOC>>>laylist()[u'park_kvartal3_utm', u'itog_region_utm', u'buf']# Close DB Manager and catch exception. Exception RuntimeError: 'wrapped C/C++ object of type PGVectorTable has been deleted' in ignored# Check TOC content again after the DB Manager is closed. Notice: no layer was added to TOC by user during DB Manager session. The names of table remains:>>>laylist()[u'park_kvartal3_utm', u'itog_region_utm', u'buf']However scripts from the Processing Toolbox displays only valid user-added layers in corresponding comboboxes, which indicates that there is another method for fetching layer names (or filtering valid ones) is implemented. How to get only layers that are displayed at TOC?
