Publishing service fail: "Login Failed. The login..."
is from an un-trusted domain. Login Failed. The login is from an un-trusted domain and can not be used with Windows Authentication. No extend error"
So i am attempting to publish via 'Share as Service' i am going though my publisher connection. When i get to the stage that ask to analyze my map i go ahead and do that then it comes back with an error 'layers data source must be registered'.
So i click on the layer and chose 'Register data source with server' but then when i do that i get the error above.
also its worth noting that i am pretty sure the database is already registered with the Server because it does show up in my data stores.
Thoughts?
Edit: i figured it out.
It has to do with my account not being a added as an user to the site.
