published ags-service shows empty map
I have some XY-Eventlayer published through ArcGIS-Server 10.2.1 First I try to connect via ODBC-Connect to the underlying Oracle Database, but the Service could not be started. So I tried to use an OLE DB Connection. The service was published (the data where copied to the server in a gdb) and started without errormessages. In the preview of the list of the services all seems fine, but the service map (using rest) is empty although the list of including layers are correctly. The Get-Request of /Mapservice/export works without any error but the response is an empty grey png. So I created a System(not user)DSN-ODBC-Connection and in ArcMap a OLE DB Connection via "Microsoft OLE DB provider for ODBC drivers" and tried again but with same result. Has anyone an idea what this could be?
