Good day. How can I make a web-map with proportional (graduated) symbols or the correct heatmap on the base of numeric data from attribute table using uMap? I have some points with data in columns "name" and "evaluation" (numeric data) in attribute table. And I can not make a heat map depending on the data from the column with the estimates, it is incorrect with only one colour, regardless of the values in the column "evaluation".Links: http://u.osmfr.org/m/49437/ (two such layers: clustered and incorrect heatmap: map is available for editing)http://umap.openstreetmap.fr/en/
