Proper projection name for NAD83 2011 revision
I have two PRJ files, one from ESRI and another from some custom GDAL/OGR code I wrote (pasted below). I was trying to have both work in NAD83 UTM10N with the 2011 revision. The ESRI file has 2011 in the PROJCS name string, but the GDAL/OGR one does not, even though all the values look the same. Are these in fact the same?
I couldn't find the ESRI version on spatialreference.org, and GeoRepository suggests that the GDAL version includes the 2011 revision.
ESRI Version (esri.prj)
PROJCS["NAD_1983_2011_UTM_Zone_10N",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-123.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]] GDAL/OGR Version (gdal_ogr.prj)
PROJCS["NAD_1983_UTM_Zone_10N",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-123],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["Meter",1]] Also, here is the output for gdalsrsinfo on each file, the PROJ.4 specs are different:
$ gdalsrsinfo esri.prj PROJ.4 : '+proj=utm +zone=10 +ellps=GRS80 +units=m +no_defs ' OGC WKT : PROJCS["NAD_1983_2011_UTM_Zone_10N", GEOGCS["GCS_NAD_1983_2011", DATUM["NAD_1983_2011", SPHEROID["GRS_1980",6378137.0,298.257222101]], PRIMEM["Greenwich",0.0], UNIT["Degree",0.0174532925199433]], PROJECTION["Transverse_Mercator"], PARAMETER["False_Easting",500000.0], PARAMETER["False_Northing",0.0], PARAMETER["Central_Meridian",-123.0], PARAMETER["Scale_Factor",0.9996], PARAMETER["Latitude_Of_Origin",0.0], UNIT["Meter",1.0]] $ gdalsrsinfo gdal_ogr.prj PROJ.4 : '+proj=utm +zone=10 +datum=NAD83 +units=m +no_defs ' OGC WKT : PROJCS["NAD_1983_UTM_Zone_10N", GEOGCS["GCS_North_American_1983", DATUM["North_American_Datum_1983", SPHEROID["GRS_1980",6378137,298.257222101]], PRIMEM["Greenwich",0], UNIT["Degree",0.017453292519943295]], PROJECTION["Transverse_Mercator"], PARAMETER["latitude_of_origin",0], PARAMETER["central_meridian",-123], PARAMETER["scale_factor",0.9996], PARAMETER["false_easting",500000], PARAMETER["false_northing",0], UNIT["Meter",1]]
