I have a dataset that includes a DTM, DSM and a shapefile (all projected in WGS84, but all of them are likely coming from ED50_UTM33N.)Those files should line up but don't. The shapefile lines up with the basemap, so seems to be properly projected. The DSM, projected in WGS84 as the shapefile, is shifted of meters. I have tried all the transformations I know without any luck.I'm starting to think that the DSM was registered in a bad way.I'm working on this data but I haven't created it. Do you have any tips to suggest how to proceed?
I'm using ArcGIS.
Many thanks in advance.
I'm using ArcGIS.
