Programmatically edit/update metadata in ArcGIS?
Has anyone succeeded in programmatically updating metadata in ArcGIS 10? Considering using Python/arcpy but ArcObjects (C# or Python/comtypes) is also a possibility.
I need to update both the FGDC and the ArcGIS-ISO format metadata, and whatever solution is used needs to be able to retain the existing (non-blank) elements along with the added elements, except where they are in conflict in which case the added elements overwrite the existing elements.
