I'm having a bit of trouble with a script that uses ArcPy. I keep getting the following error:
# Set the output raster nameout = "MMRWFS__for" + str(forestValue) + "__gra" + str(grassValue) + "__agr" + str(agricultureValue)+ "__dev" + str(developedValue) + ".asc" outASCII = "Resistance Surfaces\\" + out# Set the reclassify rangesarcpy.CheckOutExtension("Spatial")reclassifyValues = RemapRange([[11,12,"NODATA"], [21,24,developedValue],[41,43,forestValue],[71,81,grassValue],[82,82,agricultureValue],[90,95,wetlandValue]]) # 11 Open Water # 12 Perennial Ice/Snow # 21 Developed, Open Space $ # 22 Developed, Low Intensity $ # 23 Developed, Medium Intensity $ # 24 Developed, High Intensity $ # 31 Barren Land # 41 Deciduous Forest * # 42 Evergreen Forest * # 43 Mixed Forest * # 52 Shrub/Scrub # 71 Grassland/Herbaceous ** # 81 Pasture Hay ** # 82 Cultivated Crops *** # 90 Woody Wetlands 000 # 95 Emergent Herbaceous Wetlands 000# PROCESS: Reclassify and Convert to ASCIIprint "Creating " + outarcpy.RasterToASCII_conversion(Reclassify(inRaster, reclassField, reclassifyValues, "NODATA"),env.workspace + "\\" + outASCII)All the importing, etc. is correct. I'm sure there's something obvious here that I'm just missing as a novice, and I really appreciate anyone who'd be willing to point out exactly what it is I'm doing wrong. Thanks.
ExecuteError: ERROR 000622: Failed to execute (Reclassify). Parameters are not valid. ERROR 000628: Cannot set input into parameter remap.
This would seem simple to fix, but I've reached the edge of my knowledge without making headway. The most frustrating thing is that RemapRange isn't throwing any errors at all, so I don't know why Reclassify seems to have a problem with the type of parameter I'm giving it. Relevant portion of my code is below.
