I experienced problems with installing TopoJSON.
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\Microsoft.Cpp.Platform.targets(64,5): error MSB8020: The build tools for Visual Studio 2010 (Platform oolset = 'v100') cannot be found. To build using the v100 build tools, please install Visual Studio 2010 build tools. Alternatively, you may upgrade to the current Visual Studio tools by selecting the Project menu or right-click the solution, and then selecting "Upgrade Solution...". [C:\Users\Sigita\AppData\Roaming\npm\node_modules\topojson\node_modules\d3\node_modules\jsdom\node_modules\contextify\build\contextify.vcxproj]gyp ERR! build errorgyp ERR! stack Error: `C:\Program Files (x86)\MSBuild\12.0\bin\msbuild.exe` failed with exit code: 1gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:267:23)gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:797:12)gyp ERR! System Windows_NT 6.2.9200gyp ERR! command "node" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Users\Sigita\AppData\Roaming\npm\node_modules\topojson\node_modules\d3\node_modules\jsdom\node_modules\contextifygyp ERR! node -v v0.10.26gyp ERR! node-gyp -v v0.12.2gyp ERR! not ok...npm ERR! contextify@0.1.8 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR!npm ERR! Failed at the contextify@0.1.8 install script.npm ERR! This is most likely a problem with the contextify package,npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:npm ERR! node-gyp rebuildnpm ERR! You can get their info via:npm ERR! npm owner ls contextifynpm ERR! There is likely additional logging output above.npm ERR! System Windows_NT 6.2.9200npm ERR! command "C:\\Program Files\\nodejs\\\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "-g" "topojson"npm ERR! cwd C:\Users\Sigitanpm ERR! node -v v0.10.26npm ERR! npm -v 1.4.3npm ERR! code ELIFECYCLEnpm ERR!npm ERR! Additional logging details can be found in:npm ERR! C:\Users\Sigita\npm-debug.lognpm ERR! not ok code 0I'm running it on Windows 8.1. with all updates installed, npm version 1.4.3., gyp 0.13.0 and node.js 0.10.26.
