i have created the following tool to add two fields in a table and do a calculation in order to put the tool to modelbuilder. For some reason when i am going to put it as an input in an another tool it doesn't appear. I think i have done something wrong with 1. SetParameter and also 2. i haven't managed to save it as a feature class and it's only in memory.In addition i don't have a gdb or an mxd.
Also i set set parameter as an output feature class at tool's parameters but it didn't make any difference. I am using ArcGis 10.2.2, any suggestion? Thank you!
# Import system modules import arcpy from arcpy import env arcpy.overwriteoutput = True # Set environment settings inWorkspace = arcpy.GetParameterAsText(0) inFeature = arcpy.GetParameterAsText(1) outFc = arcpy.SetParameterAsText(2, "") env.workspace = inWorkspace # Set local variables fieldName1 = "bear_60" fieldName13 = "distance" # Execute AddField for 2 new fields arcpy.AddField_management(inFeature, fieldName1, "DOUBLE", "", "", "", "", "NON_NULLABLE") arcpy.AddField_management(inFeature, fieldName13, "DOUBLE", "", "", "", "", "NON_NULLABLE") # Calculate Field bear_60 inTable = inFeature fieldname = fieldName1 expression = "getCalc(!aspect!)" codeblock = """def getCalc(aspect): if aspect > 300: bear_60 = (aspect + 60) - 360 else: bear_60 = aspect + 60 return bear_60""" # Execute CalculateField arcpy.CalculateField_management(inTable, fieldname, expression, "PYTHON_9.3", codeblock) # Calculate Field distance inTable = inFeature fieldname = fieldName13 expression = "getCalc(!distance!)" codeblock = """def getCalc(distance): return 10000""" # Execute CalculateField arcpy.CalculateField_management(inTable, fieldname, expression, "PYTHON_9.3", codeblock
