I'm trying to figure out what is going on with my ArcGIS and how to fix it.
What has happened:
-everything was ok, I had 10.3 prerelease installed and I was warking with it. I was writting my srcipt and once up on a time...
-I tried to run Calculate Field but i got the message "Adding this item is not supported or the application that opens it is not found" - the same was with other tools in Field toolbox and some other toolboxes.
-I reinstalled ArcGIS 10.3 - didn't help
-I reinstalled Python and ArcGIS 10.3 - didn't help
-I uninstalled 10.3 and came back to 10.2 - Tools worked. My script did not worked, I got messages that numpy is not found or ArcGIS simply crashed to Windows. Also rewritting script and trying to run tools (Add XY) from python window in ArcMap didn't succed.
-I reinstalled my Windows and tried to instal my 10.3 again - I'm still getting the same error "Adding this item..."
Now I'm trying to install 10.3 from newer installer (from ESRI website). If this doesn't help I will try again with 10.2.
If you need any additional info, just tell me.
What has happened:
