I have a PostgreSQL table and view:
CREATE TABLE lines ( geom geometry(MultiLineString,4326), type character varying(254), login text, gid serial NOT NULL, CONSTRAINT lines_pkey PRIMARY KEY (gid)) CREATE OR REPLACE VIEW lines_view AS SELECT lines.geom, lines.type, lines.gid FROM lines; CREATE OR REPLACE RULE add AS ON INSERT TO lines_view DO INSTEAD INSERT INTO lines (geom, type, login) VALUES (new.geom, new.type, "current_user"()); CREATE OR REPLACE RULE del AS ON DELETE TO lines_view DO INSTEAD DELETE FROM lines WHERE lines.login = "current_user"()::text AND lines.gid = old.gid; CREATE OR REPLACE RULE upd AS ON UPDATE TO lines_view DO INSTEAD UPDATE lines SET geom = new.geom, type = new.type, login = "current_user"() WHERE lines.login = "current_user"()::text AND lines.gid = new.gid;So, problem is when I load this lines_view in QGIS as layer and add lines, after saving I cannot use "node tool" to new lines ("Node tool: could not snap to a segment on the current layer"). But when I use move tool on them (just select "move feature(s)" button and click on new line) "node tool" start working as usual. Can some one help me with this?
