I have matplotlib installed on a Mac (Mavericks) via pip, which means the matplotlib files get installed under /System/Library/...
I tried installing the most recent version of QGIS, and the install fails because it can't find matplotlib. I'm thinking this is because I didn't use easy_install, which appears to put packages instead under /Library/...
Is there an easy way to tell QGIS to look for packages under /System/Library - is it merely a matter of setting some environment variable that QGIS looks at ?
thanks !
Update:
thanks !
Update:
- I'm installing QGIS from the .dmg package provided at kyngchaos.com
- the error message started when I double click the .dmg to install it. I get a popup complaining that matplotlib is not installed even though it is installed and command line python can see it.
