Problem with Leaflet Boundary Canvas plugin
I'm trying to identify the source of a problem that I'm having, I cannot show a tile layer(created with gdal2tiles) inside a polygon generated in Leaflet, using the plug-in BoundaryCanvas(https://github.com/aparshin/leaflet-boundary-canvas)
Some facts:
  • The tile layer created with Gdal2tiles.py, can be shown in the map with Leaflet if I just use the object tileLayer. From this I understand that the tile layer was generated correctly.
  • If I use the object tileLayer.BoundaryCanvas(with boundary a polygon), the tile is not shown and in the browser there are errors missing PNG files(it's trying to download png's that are not in the path structure of the tile layer).
  • If I use the same plug-in with for example the TMS from OSM http://{s}.tile.osm.org/{z}/{x}/{y}.png, it works properly I can show that tile inside the polygon.
At this point I don't know if the errors comes from the Leaflet plug-in or from the tile layer generation, any idea about how to find out would be pretty much appreciated.
I'm using:
gdal2tiles.py --profile=geodetic -z 0-15 -w none ./terra.tif gdalinfo
Driver: GTiff/GeoTIFF
Files: TerraColor_SanFrancisco_US_15m.tif
Size is 7204 x 7204
Coordinate System is:
GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS 84",6378137,298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich",0], UNIT["degree",0.0174532925199433], AUTHORITY["EPSG","4326"]] Origin = (-122.809804036593036,38.285436652047451) Pixel Size = (0.000138800000000,-0.000138800000000) Metadata:
AREA_OR_POINT=Area Image Structure Metadata:
INTERLEAVE=PIXEL Corner Coordinates:
Upper Left (-122.8098040, 38.2854367) (122d48'35.29"W, 38d17' 7.57"N) Lower Left (-122.8098040, 37.2855215) (122d48'35.29"W, 37d17' 7.88"N) Upper Right (-121.8098888, 38.2854367) (121d48'35.60"W, 38d17' 7.57"N) Lower Right (-121.8098888, 37.2855215) (121d48'35.60"W, 37d17' 7.88"N) Center (-122.3098464, 37.7854791) (122d18'35.45"W, 37d47' 7.72"N) Band 1 Block=7204x1 Type=Byte, ColorInterp=Red Band 2 Block=7204x1 Type=Byte, ColorInterp=Green Band 3 Block=7204x1 Type=Byte, ColorInterp=Blue
