Problem with import csv to cartodb
Iam install cartodb on my local machine and iam cant upload data via import.Data to upload
Latitude,Longitude,Name48.1,0.25,"First point"49.2,1.1,"Second point"47.5,0.75,"Third point"i am recieve error log Any ideas ?
true: Importing data from /tmp/imports/20151014-21811-1binquy/123.csvtrue: File-based import loadtrue: Detected encoding ISO-8859-1true: Using database connection with {:adapter=>"postgres", :encoding=>"unicode", :host=>"localhost", :port=>5432, :database=>"cartodb_dev_user_f4f00efc-27e9-4321-af96-8bbb73245090_db", :username=>"postgres", :conn_validator_timeout=>900, :pool=>50, :user=>"development_cartodb_user_f4f00efc-27e9-4321-af96-8bbb73245090"}false: ogr2ogr call: OSM_USE_CUSTOM_INDEXING=NO PG_USE_COPY=YES PGCLIENTENCODING=ISO-8859-1 -f PostgreSQL PG:"host=localhost port=5432 user=development_cartodb_user_f4f00efc-27e9-4321-af96-8bbb73245090 dbname=cartodb_dev_user_f4f00efc-27e9-4321-af96-8bbb73245090_db password=53e933beffd3aef71b99afe6586c9afca5804943development_cartodb_user_f4f00efc-27e9-4321-af96-8bbb73245090" -lco DIM=2 -lco PRECISION=NO /tmp/imports/20151014-21811-1binquy/123.csv -nln cdb_importer.importer_e2b0c8ba726711e59e5400505681560b -nlt PROMOTE_TO_MULTI true: ogr2ogr output: sh: -f: command not foundtrue: ogr2ogr exit code: 325122015-10-14 11:37:03 UTC: Ogr2ogr FAILED!2015-10-14 11:37:03 UTC: ogr2ogr.exit_code = 325122015-10-14 11:37:03 UTC: ogr2ogr.command = OSM_USE_CUSTOM_INDEXING=NO PG_USE_COPY=YES PGCLIENTENCODING=ISO-8859-1 -f PostgreSQL PG:"host=localhost port=5432 user=development_cartodb_user_f4f00efc-27e9-4321-af96-8bbb73245090 dbname=cartodb_dev_user_f4f00efc-27e9-4321-af96-8bbb73245090_db password=53e933beffd3aef71b99afe6586c9afca5804943development_cartodb_user_f4f00efc-27e9-4321-af96-8bbb73245090" -lco DIM=2 -lco PRECISION=NO /tmp/imports/20151014-21811-1binquy/123.csv -nln cdb_importer.importer_e2b0c8ba726711e59e5400505681560b -nlt PROMOTE_TO_MULTI 2015-10-14 11:37:03 UTC: ogr2ogr.command_output = sh: -f: command not foundtrue: Errored importing data from /tmp/imports/20151014-21811-1binquy/123.csv:===LOG END===true: ----------------------------------------------------false: ["/opt/openmap/carto/cartodb/services/importer/lib/importer/loader.rb:335:in `check_for_import_errors'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/loader.rb:268:in `run_ogr2ogr'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/loader.rb:63:in `block (2 levels) in run'", "/opt/openmap/carto/cartodb/lib/cartodb/stats/aggregator.rb:97:in `method_missing'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/loader.rb:62:in `block in run'", "/opt/openmap/carto/cartodb/lib/cartodb/stats/aggregator.rb:97:in `method_missing'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/loader.rb:52:in `run'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:222:in `file_based_loader_run'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:177:in `import'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:327:in `execute_import'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:256:in `block (3 levels) in single_resource_import'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:249:in `each'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:249:in `each_with_index'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:249:in `block (2 levels) in single_resource_import'", "/opt/openmap/carto/cartodb/lib/cartodb/stats/aggregator.rb:97:in `method_missing'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:248:in `block in single_resource_import'", "/opt/openmap/carto/cartodb/lib/cartodb/stats/aggregator.rb:97:in `method_missing'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:226:in `single_resource_import'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:95:in `run_import'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:88:in `block in run'", "/opt/openmap/carto/cartodb/lib/cartodb/stats/aggregator.rb:97:in `method_missing'", "/opt/openmap/carto/cartodb/services/importer/lib/importer/runner.rb:87:in `run'", "/opt/openmap/carto/cartodb/app/connectors/importer.rb:39:in `run'", "/opt/openmap/carto/cartodb/app/models/data_import.rb:618:in `new_importer'", "/opt/openmap/carto/cartodb/app/models/data_import.rb:354:in `dispatch'", "/opt/openmap/carto/cartodb/app/models/data_import.rb:163:in `run_import!'", "/opt/openmap/carto/cartodb/lib/resque/importer_jobs.rb:9:in `block in perform'", "/opt/openmap/carto/cartodb/lib/resque/base_job.rb:21:in `call'", "/opt/openmap/carto/cartodb/lib/resque/base_job.rb:21:in `run_action'", "/opt/openmap/carto/cartodb/lib/resque/importer_jobs.rb:9:in `perform'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/job.rb:240:in `block (3 levels) in perform'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-metrics-0.1.1/lib/resque/metrics.rb:353:in `around_perform_metrics'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/job.rb:239:in `block (2 levels) in perform'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/job.rb:247:in `call'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/job.rb:247:in `perform'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/worker.rb:250:in `perform'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/worker.rb:189:in `block in work'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/worker.rb:166:in `loop'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/worker.rb:166:in `work'", "/usr/local/lib/ruby/gems/1.9.1/gems/resque-1.25.2/lib/resque/tasks.rb:41:in `block (2 levels) in '", "/usr/local/lib/ruby/1.9.1/rake/task.rb:205:in `call'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:205:in `block in execute'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:200:in `each'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:200:in `execute'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:158:in `block in invoke_with_call_chain'", "/usr/local/lib/ruby/1.9.1/monitor.rb:211:in `mon_synchronize'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:151:in `invoke_with_call_chain'", "/usr/local/lib/ruby/1.9.1/rake/task.rb:144:in `invoke'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:116:in `invoke_task'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:94:in `block (2 levels) in top_level'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:94:in `each'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:94:in `block in top_level'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:133:in `standard_exception_handling'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:88:in `top_level'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:66:in `block in run'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:133:in `standard_exception_handling'", "/usr/local/lib/ruby/1.9.1/rake/application.rb:63:in `run'", "/usr/local/bin/rake:32:in `'"]true: ----------------------------------------------------2015-10-14 11:37:03 UTC: Proceeding to register2015-10-14 11:37:03 UTC: After importer run2015-10-14 11:37:03 UTC: After dispatch2015-10-14 11:37:03 UTC: ERROR!===LOG END===
