Problem with adding placemark from kml file with specific id
I have a problem with adding a vector layer from kml file. I am trying to make XMLHttpRequest and add only a placemark with specific id. Nothing is displaying on the map. Request is successful and variable data contains proper snippet of kml file. I'm pretty sure I'm making some noob mistake. Here is my code:
map = new OpenLayers.Map("mapdiv");map.addLayer(new OpenLayers.Layer.OSM());var idOfPlacemark = "test"; var req = new XMLHttpRequest(); req.open('GET', 'boundaries.kml', false); req.send(null); if(req.status == 200) dump(req.responseText);var data = req.responseXML.querySelector("[id=" + idOfPlacemark + "]"); var format = new OpenLayers.Format.KML;test_layer = new OpenLayers.Layer.Vector("test");test_placemark = format.read(data.outerHTML);test_layer.addFeatures(test_placemark);map.addLayer(test_layer);var layer_switcher= new OpenLayers.Control.LayerSwitcher({});map.addControl(layer_switcher);var lonLat = new OpenLayers.LonLat(19.274483, 50.203275) .transform( new OpenLayers.Projection("EPSG:4326"), // transform from WGS 1984 map.getProjectionObject() // to Spherical Mercator Projection );var zoom=13;map.setCenter (lonLat, zoom);And here is my kml file:
Name of placemark This is descr 1 relativeToGround 19.212462, 50.200544 19.21287, 50.200399 19.21346, 50.19998 19.213857, 50.199603 19.214146, 50.199548 19.214715, 50.199541 19.215766, 50.199761 19.216743, 50.199987 19.217311, 50.200083 19.218041, 50.200028 19.21876, 50.199871 19.219178, 50.19961 19.219446, 50.199376 19.219253, 50.199046 19.218331, 50.198318 19.217741, 50.197845 19.217333, 50.197508 19.217086, 50.196986 19.216421, 50.196279 19.215606, 50.196004 19.214737, 50.196024 19.213996, 50.196182 19.213331, 50.196423 19.212065, 50.197055 19.211089, 50.1977 19.210874, 50.198298 19.210896, 50.199005 19.211217, 50.199747 19.211647, 50.200228 19.212054, 50.200592 19.212301, 50.200598
