I am trying to upload a large number of 3 band rasters to a PostGIS database using raster2pgsql on the command line in Windows 7. Here is my command:
raster2pgsql -I -C -s 27700 -F -t 100x100 -M F:\Filedirectory\myfile.tif mytablename | psql -h localhost -p 5942 -U postgres -d mydatabaseSometimes (though increasingly rarely it seems) the upload works, sometimes I get the following message:
Processing 1/1: F:\Filedirectory\myfile.tif ERROR 1: TIFFFillStrip:Integer overflowERROR 1: TIFFReadEncodedStrip() failed.ERROR 1: F:\Filedirectory\myfile.tif , band 1: IReadBlock failed at X offset 0, Y offset 0ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0ERROR: rt_raster_from_gdal_dataset: Could not get data from GDAL rasterERROR: convert_raster: Could not convert VRT dataset to PostGIS rasterERROR: process_rasters: Could not process raster: F:\Filedirectory\myfile.tif ERROR: Unable to process rastersOther times I get a string of the usual INSERT 0 1 and then the same message comes up.
I have been unable to find an explanation for the meaning of this message, and I cannot find anything consistent between the files that fail and the ones that don't. Does anyone know what this message means? and how I can fix the problem?
Thanks,
Thanks,
