problem to open a netCDF and create a raster file
I want to open a netCDF file and create a raster with ArcMap 10.2. The file contains the mean monthly temperature for Switzerland. I found it in meteoswiss web site.
I tried to open it with the multidimension tool and make a netCDF raster layer but when I select the file to open automatically gis put the info in X dimension and Y dimension but I have the error 000237 (One or more dimensions are invalid). Even if I change the variable for the x and y dimensions I have still the same error.
I tried also to drop the file directly into ArcMap and in that case I have just a point (and a message saying that there is no coordinate system so I added the coordinate system, WGS 1984, but nothing changes).
I found this question that I found helpful: Issues with importing a netcdf file to arcgis as a point feature layer but my problem is that I can't create the file with the coordinate.
How can I solve my problem?
