Problem importing sqlite into Postgres (with PostGis) using ogr2ogr
I am trying to import a very large sqlite file into Postgres SQL 9.3.
The first tool I tried to use was OGR2GUI (http://www.ogr2gui.ca/). The 64 Bit version does nothing, whilst the 32 bit version says
  • unable to open ogr2ogr !
I have tried running org2ogr from the command line too, I have tried:
ogr2ogr --config SQLITE_LIST_ALL_TABLES YES -f "PostgreSQL" PG:"dbname='mydatabaseName' active_schema=myschema schemas=public host='localhost' port='myportnumber' user='myusername' password='mypassword' " -overwrite -lco SCHEMA=myschema -lco GEOMETRY_NAME=geometry -lco SPATIAL_INDEX=YES myfilename.sqlite myfilenameogr2ogr -f "PostgreSQL" PG:"dbname=mydatabaseName" myfilename.sqlite myfilenameogr2ogr -f PostgreSQL PG:"host=localhost user=myusername password=mypassword dbname=mydatabaseName" -lco LAUNDER="YES" myfilename.sqlite -skipfailuresAnd various iterations on these, each time I get:
Unable to open datasource'myfilename.sqlite' with the following drivers -> ESRI Shapefile -> MapInfo File -> UK .NTF -> SDTS -> TIGER -> S57 -> DGN -> VRT -> REC -> Memory -> BNA -> CSV -> GML -> GPX -> KML -> GeoJSON -> GMT -> WAsP -> PostgreSQL -> PCIDSK -> OpenFileGDB -> XPlane -> AVCBin -> AVCE00 -> DXF -> Geoconcept -> GeoRSS -> GPSTrackMaker -> PGDump -> GPSBabel -> SUA -> OpenAir -> PDS -> HTF -> AeronavFAA -> EDIGEO -> SVG -> Idrisi -> ARCGEN -> SEGUKOOA -> SEGY -> PDF -> SXFOf course sqlite is not on this list, but how can I add it? I have tried running osgeo set-up, but there is no option I can find to add it.
Thanks for your time
