I visualize (display) a municipality with the plugin register with the land registry in spatiality and in projection Lambert 93. I need the bottom on Autocad in projection CC47 thus I re-throw (re-plan) on QGIS by choosing as current SCR the CC47 (the reprojection in the air bustles). Up to there, everything works.
Then, in Project, I choose export DXF and I make my export. It sticks (there is a problem) when I visualize (display) the created file DXF because either I have no object inside, or I have all the municipality but in Lambert 93 (as I mark or not "exporter only the visible entities on the influence of the card (map)").
If somebody in the solution, beforehand thank you.
