Problem creating parameters for a tool
First post so please excuse any mistakes. I am still an arcpy newbie, but I think I have a basic understanding of fundamentals including syntax, variables, modules, etc. My question is regarding the usage of parameters while creating a tool.
I am trying to create a tool that will calculate and summarize the area of a feature layer "levels". I have the script working for the calculation and summarization of the feature layer which outputs as a table, but I am not able to get the parameter inputs for the tool working. Syntax checks out (using PyScripter as IDE) but when I try to run the tool in ArcMap "This tool has no parameters" appears. Ideally, I would like the user to input the feature layer "levels" as a parameter and return the summary table, but a message window showing area summary would be even better if thats possible. Please let me know what might be going wrong with the parameters, or how I could change the output to a message window. Any input is greatly appreciated, thank you.
import arcpy class GeoArea(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "GeoArea" self.alias = "Tom" # List of tool classes associated with this toolbox self.tools = [LevelsCalcTool] class LevelsCalcTool(object): def __init__(self): self.label = "LevelsCalcTool" self.description = "Calculates and summarizes Levels' area in square meters" self.canRunInBackground = False def getParameterInfo(self): param0 = arcpy.Parameter( displayName="Input Features", name="in_features", datatype="GPFeatureLayer", parameterType="Required", direction="Input") params = [param0] return params def execute(self, parameters, messages): """The source code of the tool.""" arcpy.AddField_management(params,"area","DOUBLE","#","#","#","#","NULLABLE","NON_REQUIRED","#") arcpy.CalculateField_management(params,"area","!shape.area@squaremeters!","PYTHON_9.3","#") arcpy.Statistics_analysis(params, "out_table.dbf", [["area", "SUM"]]) return
