Printing semi-transparent elements using ArcObjects?
I highlight some features with a semi transparent color via an ILayerExtensionDraw. When I print the ActiveView of the PageLayoutControl with IPrintAndExport the highlightning is not on the printout.
In the print method I get the printers HDc and save it to a static variable which the LayerExtension reads from.
System.Windows.Forms.PrintDialog printDialog = new System.Windows.Forms.PrintDialog(); System.Windows.Forms.DialogResult res = printDialog.ShowDialog(); if (res == System.Windows.Forms.DialogResult.Cancel) return false; // ... assigning printer settings here... System.Drawing.Graphics graphics = printDialog.PrinterSettings.CreateMeasurementGraphics(); MyLayerExtension.CurrentPrinterHdc = graphics.GetHdc(); PrintAndExport.Print(docActiveView, docPrinter, _pageLayoutControl.PageLayout.Page, 1, iResampleRatio, null); graphics.ReleaseHdc(); MyLayerExtension.CurrentPrinterHdc = IntPtr.Zero;The LayerExtension reads the IntPtr and uses it to draw the highlightning to the printer, but it is not shown on the print out.
SimpleFillSymbol fillSymbol = new SimpleFillSymbol();fillSymbol.Style = esriSimpleFillStyle.esriSFSSolid;fillSymbol.Outline = new ESRI.ArcGIS.Display.SimpleLineSymbol();fillSymbol.Color = Utilities.CreateColor(System.Drawing.Color.Khaki);pDisplay.Filter = new TransparencyDisplayFilterClass { Transparency = 127 }; pDisplay.SetSymbol((ISymbol)fillSymbol);pDisplay.StartDrawing(pDisplay.hDC, (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache);if (CurrentPrinterHdc != IntPtr.Zero) pDisplay.StartDrawing(CurrentPrinterHdc.ToInt32(), (System.Int16)ESRI.ArcGIS.Display.esriScreenCache.esriNoScreenCache);pDisplay.DrawPolygon(feature.Shape);pDisplay.FinishDrawing();The LayerExtension does get called on printing.
What did I miss?
As far as I understand the HDc now the drawing on the printers handle would only work, if I use the HDc to print later on again, which is not a real option.
Is there any other way to get the transparent (!) highlightning printed?
