Print City Map in High Resolution with TileMill (OSM Data)
I'm rather beginner in Print Map and GIS. I'd like to print the map of my little city using the data in OpenStreetMap. I've got an environment(local) with OSM DataBase and I'm using TileMill to create StyleSheet and export data. My problem is the definition of export. As you know, in TileMill you can export data in SVG, PDF and XML, and you can define just the BBox. The Resolution seems hard coded and set to 72dpi. To increase the quality and the details of export image I have to reduce the BBox (since to have a higher zoom level).Since I need to print a classic city map (the paper size is, more or less, 80cm X 50cm and the city area 2km X 1km), does anybody have an idea for print it with a good resolution?If i set 300 dpi as resolution, I'll solve my issue, but maybe I can't.As I said before, I have a local environment, but if someone knows some other ways ... I appreciate your helpAny ideas?
Thanks in advance and Regards,
Paolo
