I want to create a Postgresql view using point data. When I create the view, the geometry_columns table updates appropriately. Attempting to load in QGIS produces the error “(the_geom) sql = is an invalid layer and cannot be loaded”.
For all of the working (polygon) views, when I load them in QGIS, I need to specify the primary key column (as documented here: How to make a spatial view in PostGIS and add it as a layer in QGIS?). When I try to add my point view, I am not given the option to choose the primary key.
I have tried several tables all with Point geometry and nothing is working. The tables do have the 3 constraints: enforce_dims_the_geom, enforce_geotype_the_geom, and enforce_srid_the_geom. I have also run st_isvalidreason (the_geom) and the geometry is valid. How do I get a view with point data to show the selection for a primary key in QGIS?
We are running PostGIS 1.4 and I am using QGIS 1.8.
