PostGIS Topology Requires Admin
I am running PostGIS on an Ubuntu server. I am able to add the Topology extension via CREATE EXTENSION, but when I try to use it as anything other than an admin I am denied permission.
I ran GRANT USAGE ON SCHEMA topology TO public, as suggested in this chain. When I run CreateTopology() I get a permissions error like the following:
ERROR: permission denied for sequence topology_id_seq
CONTEXT: PL/pgSQL function topology.createtopology(character varying,integer,double precision,boolean) line 17 at FOR over SELECT rows
I'm guessing this means that I need to monkey with more permissions on the topology schema. However,
  1. That seems an odd design flaw. Shouldn't the Topology extension automatically take care of permissions when it is created, just like the PostGIS extension does for the spatial_ref_sys table?
  2. I'm not sure how far down the permissions rabbit hole I need to go in order to make the extension usable.
Has anyone else encountered this issue?
Here's the output of SELECT postgis_full_version() from the regular user:
"POSTGIS="2.1.5 r13152" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.11.2, released 2015/02/10" LIBXML="2.9.1" LIBJSON="UNKNOWN" TOPOLOGY RASTER"
