postgis resampling two rasters to a common grid system?
I am testing the PostGIS map algebra (ST_MapAlgebra) on two different raster tables.
Each table contains a single image/row. They have the same SRID but different, overlapping extents and different ground resolution. What I did was:
SELECT ST_MapAlgebra(t1.rast,t2.rast ,'([rast1]+0.001)/([rast2]+0.001)') AS rastFROM t1, t2 And I got an error saying that
rt_raster_iterator: The set of rasters provided (custom extent included, if appropriate) do not have the same alignment
Now, what I want to do is to resample t1.rast and t2.rast to their common area (i.e. intersection) at the higher resolution of the two rasters.
My questions are:
Is there a function for this in PostGIS (2.1+)?
If not, how should I go about making such a query?
Thanks,
P.S. I looked at ST_REsample, and it seems that it can only sample one image to the reference grid of another. Also, the documentation says that it does not handle SRID since PostGIS 2.1.
