I'm currently working on a project that involves crowdsourced data collection using ArcGIS Online (Organization version). The only problem I have with ArcGIS Online editing is that when you make a map public, I can't seem to find a way to "safeguard" the edits - any point someone adds to the map (Malicious or good) is there unless I go and manually remove it. Because it is crowd sourced, the general public will most likely not want to install a special app or really do any other work than clicking a link and adding data.
Is there a way to enable post approval? If not, is there a way to sort the points in the attribute table by date created, and then I could check weekly to see what points are added, and remove any bad ones that occurred through the week? I also have ArcGIS 10.2 with advanced license if that matters at all.
