When a WMTS in Portal for ArcGIS 10.3.1 is opened (via Portal) in an mxd, the WMTS layer properties are not standard. The; Source, Layers, and Advanced tabs are missing. When the portal WMTS layer used as an input into arcpy.ExportMapServerCache_server() it fails without any errors.
I've discovered that if you copy and paste the layer into the same data frame, the layer regains all of it's normal properties. I think the portal extracted layer is actually put in a hidden optimized base map layer.
I need to use ArcPy to cache this service locally as a part of a greater user workflow. However beofre I proceed I need a method to handle this "optimized portal WMTS layer".. Has anyone experienced this and then figured out a way around it?
